Auteur Sujet: Porsche 944 GTR SHK  (Lu 3855 fois)
Porsche 944 GTR SHK
« le: 25 Novembre 2015, 23:13:57 »
Une voiture qui ne date pas d'hier et qui, depuis, a été revendu. On en avait pas parlé sur un fil de discussion de Gilbert83? Une terreur des pistes à l'époque à priori.
Turbo is an modified K27/9 with 23 PSI Boost, no Overboost, we still run 23 PSI and the Turbo hold it up to 7400 rpm !!! Fuel is Standard 98 ROZ, The ECU is an modified 968 with an Extern Manifold Air pressure unit. but we can also use now an Stock ECU with an 997 Turbo Pressure Unit !! we will do this with my Engine, in my Street Car. Same Engine, same Turbo :-D
The Gearbox is an Manual 6-Speed, with 1st and 2nd Gear are Stock 968 Turbo RS and 3rd, 4th, 5th and 6th Gear are straight teeth with Top Speed in 6th Gear 265 KM/H @ 7400 rpm.
More: 944 Turbo GTR, race-ready vehicle wagons pass and street legal! 2008 Start of classic cars in 2009 and 2010 Porsche Club Trophy Historic Challenge with numerous class and overall victories in 2011 Special Touring Car Trophy (STT) Engine: Displacement: 2.5 liters Power: 460 hp at 6770 /. Torque: 500 Nm at 4760 /. Boost pressure: 1.6 bar max. Speed: 7250 /. Increased compression ratio (8.0 to 1 from 8.6 to 1!), Modified camshafts, closed deck (cylinder are no longer free), Carillo connecting rod, map matching, electronic sequential fuel injection and sequential adaptive knock control, intake manifold air flow detection via ! ! K 27 Charger,100-Zeller Sportkat, 4 "exhaust, crankshaft plasma nitrided and fine balanced Revised intake manifold, verstarkter block Transmission: 968 Turbo RS 6-speed manual transmission special translation - 60% limited slip differential Suspension: H & R shocks with H & R coil springs shock effect on the VA in 6 steps adjustable steering knuckles stored Unibal tires: VA 27/65 - 18 to 10.5 x 18 BBS rear 30/65 - 18 to 11.5 x 18 BBS forged with central locking 3-set BBS wheels / tires: Sport / rain / slick brakes: Bosch 4-channel 4-cycle racing ABS-5, hydraulic disc brake booster - Front: 350mm Rear: 320mm body: easy, rewelded, and with a safety cell versehen.Leergewicht 1,150 kg The vehicle is equipped with a PI data recording system equipped.
Message d'un Allemand à propos de cette voiture:
The car so fats that it was banned from the german club racing unless it will race with smaler tires and no sliks!! Owner was not happy and changed the race series. It has air jacks centarl locks etc etc. Unfortunately the builder Harry weishaupt a well known guy 15 years ago in the 964 scene in Germany died 2 years ago. The car is for sale now. The companys name is SHC
-> http://www.shk-fahrzeugtechnik.de/bildergalerie/
