Auteur Sujet: 924 GTS REPLICA  (Lu 9519 fois)
924 GTS REPLICA
« le: 10 Juin 2013, 22:56:53 »
 :shock:
Titch va pas s'en remettre :)
http://www.924board.org/viewtopic.php?p=349254#349254
Citation de: Cédric
Ok guys, take a deep breath and sit down, this is a thread you probably will follow from now on :). I got the permission from the owner to throw some pics up on his absolutely fantastic reproduction of a 924 GTS rally spec. The aim is to go rallying in the forest (http://www.midnattssolsrallyt.com/gb/index.php for example) at different historic events. And it is a complete reproduction, including new castings if needed for the homologation. Still cheaper than buy them from the rest stocks of GTS/GTR parts. Engine is full race spec with correct dry sump system etc, including v8 kjet. Gearbox is custom GTS gears etc, everything is top notch down to every little detail. As an engineer and 924/racing  enthusiast this is as good as it gets :) Enjoy !
So, it all started with an ex CGT project car...
A "normal" GTS engine bay used to take measurments for the design of some parts..
There is more to come....stay tuned !
Citation de: Cédric
The castings are made by a very skilled company here in sweden, they are used to make prototype castings. Although not these GTS parts every day :) Here is some pics from the wheel hub and intake process.
Re : 924 GTS REPLICA
« Réponse #1 le: 11 Juin 2013, 07:08:08 »
 8) 8) 8)
pierre944S2
« Réponse #2 le: 11 Juin 2013, 08:03:14 »
et bé que de boulot  :shock:
« Réponse #3 le: 11 Juin 2013, 08:28:35 »
Wow! Demi-molle en vue  :shock:
« Réponse #4 le: 11 Juin 2013, 22:26:49 »
Citation de: Cédric
And here we go,  more goodies!
Ported, hot cam etc:
Boxed rear suspension with ball joints.
Getting close !
Hors ligne Tanguy
« Réponse #5 le: 11 Juin 2013, 22:58:00 »
 :shock: :shock: :shock:
Plus de PMA (snif)
Hors ligne felinkinkin
« Réponse #6 le: 11 Juin 2013, 23:03:48 »
 :shock: :shock: :shock: :shock: :shock:
Hors ligne OLIV951
« Réponse #7 le: 12 Juin 2013, 11:01:48 »
Alors là chapeau!!!!!!!!!!!   :shock:   :enaccord6: :enaccord6: :enaccord6: ;)
Hors ligne Mr T
  • Ville: gironde
« Réponse #8 le: 12 Juin 2013, 12:51:10 »
Il y a des gonzes qui ne font pas les choses à moitié.  :shock: :mrgreen:
89' 944 s2 targa blanche
Hors ligne Bruno Brazil
  • Ville: Oisly
« Réponse #9 le: 12 Juin 2013, 14:57:29 »
Ben, là, on est carrément dans l'exception...
En tout cas, niveau fonderie, c'est juste incroyable de se dire que ça coute moins cher de faire couler la pièce que d'en racheter une... Porsche et Freisinger devraient songer à redevenir un peu plus raisonnables concernant les pris des pièces NOS... Car avec les nouvelles technos d'impression 3D, faire faire une pièce de fonderie en "cire perdue" devrait devenir un jeu d'enfant... Des imprimantes comme celle-ci : http://www.multistation.com/3Z-PRO permettent d'imprimer avec une précision de 2 centièmes... Résultat, dans le futur, il y a fort à parier que certaines pièces devenues hors de prix  comme des culasses, voire carrément des blocs moteur, redeviendront accessibles !
Sinon, y'a pas à dire... Le gars fait ça "à la bien" !!
Hors ligne portoy06
« Réponse #10 le: 14 Juin 2013, 17:01:55 »
c'est du lourd
ca  plaisante pas  :shock:
944 S2 , 944 2.7 , 944 PH1 715  blanc alpin pour les 3
seb968
« Réponse #11 le: 14 Juin 2013, 19:46:22 »
Ou la la, il y en a qui plaisentent pas :shock:
« Réponse #12 le: 15 Juin 2013, 08:48:34 »
c est quoi cette modification de fixation du silent bloc/support moteur?  :roll:
En tout cas super de refabriquer les pièces iintrouvable en fonderie d alu  :shock:
Re : Re : 924 GTS REPLICA
« Réponse #13 le: 15 Juin 2013, 09:10:57 »
... et des aspects de surface qui se sont grandement améliorés par rapport aux premiers modèles. ;)
« Réponse #14 le: 15 Juin 2013, 09:22:00 »
la base ce st quoi? une vraie carrera gt, ou deja une 924 turbo look carrera gt?
